Re-doing work on the wheel pants... putting the mud guard in distorted the rear sections and wouldnt fit!
Lots of fiddling, more filling and sanding, but now fit well and easy to take on and off. Added three positioning rods fitting to tubes on the front section to make mounting easier. Need to create some access holes for the air valves next.
Changed the brake lines... apparently Teflon lines are better fo brake fluid; lines are also lighter and smaller external diameter. More tools....
