Took out the Nav wire in the port wing that would have needed a juncyion at the wing root, and ran a new RG400 from the panel to the tip, leaving enough for an access loop...one less connection and three fewer joints. Made the RG400 comm leads for the two radios, and installed one to the housing box for Comm2
Tidied up the wire bundles through the conduits, and ensured labels at each end matched. Then wrote the configuration down for the future! Put the rear side panels in.
