Brief Description: Fuel lines to gascolator fitted, fuel pump install
Bent the pipes from the tank to the gascolators. Installed the Andair fuel pump where the old filter went; much more accessable. Ran the fuel pipe from the pump to the firewall then ran out of connectors! LAS order again...
then realised I'd put the outfow and inflow to the gascolator in reverse.. doh! How to turn 12' of fuelline into a bin full of bent 10" pieces!
Aerolab gascolator installation ..unfortunately pipes are reversed!
