More work on design and construction of electric rudder trim. Servo installed onto mounting plate, and the pushrod fabricated ti take the rudder return springs. Thimble swaged onto cables using my new hydraulic press... very satisfying! Seat bottom attached, and cable runs needed a bit of modification to allow enough cable travel to permit full rudder movement with room to spare. Will need new pulley mount, moved out laterally
After considerable reflection, I decided it didnt do what I wanted it to do... so I scrapped it all! No point persuing something that isnt goinfg to work.
