Next step in the build is constriction of the seat backs. Front one went well, everything cleaned, edged etc and trial fitted. 2 stage priming as before, but had an issue with viscosity of the 2-pack epoxy... seemd far too thin even with 50% less thinner than usually required. Guess I need to stir it for longer before mixing. Looked ok afte sanding down but will need a second coat later.
Fun with the rear seat assembly as some parts were missing; pulled the storeroom apart looking for three pieces taht were missing... then check the inventory and found I'd cancelled their order as the Fastback kit uses their own parts! Another hour of my life wasted...
