Brief Description: SB Wing skin fettling before final priming
Did a bit of filling and sanding to smooth out a slight dip along one rib... looked like it would have been better with a small shim beneath. Looked fine once a very thin layer of filler applied. Will ensure the other side is perfectly straight before rivetting the final skin. Good practice and learning for the fuselage top skin fittings, wheer imperfections will really show up! More primer on the floor, this time as dry dust rather than overspray!
