Reassembled flaperon assembly for riveting of the bottom section. Riveted ribs & hinge brackets to spar. Then I riveted the bottom section together. Laid out center line on upper spar & ribs. Rechecked bench for level and flat, it's perfect. Made wooden supports & screwed to bench for the straps to go around when when skinning. Ready to drill & cleco the upper section.
