Riveted Lower Rear Skin (7V7-3), Trailing Edge Skins (7V7-4 & 5) & Flaperon Support "L" channels in place. Note: Did not rivet at root & tip for easier access when working on these later. Did not rivet jury strut angles at this time so they won't get damaged. Removed Spar Supports & clamps. Prepared wing to turn over by placing 3-web clamps around nose skin for support while turning over. Turned wing over & leveled. Clamped 1"x2"x10' pieces of wood on top & bottom edge of trailing edge of skins to protect them from the clamps and another under that to raise the trailing edge of wing a total 1/12-inches to level it.
