Some time spent with squaring, layout and clamping of rear ribs & channel. Formed flange on end of channel to go between ribs 2 & 3. Cut 6 rear rib angles for inboard end of channels. Added plate to side of template for channel, 3-holes drilled will use to drill into rib & end of channel.
