Eds Web Site
Date:  11-28-2003
Number of Hours:  1.50
Brief Description:  Flaperon, Outboard
Up-drilled all holes to # 30. Upper skin came 3 mm short of trailing edge lower skin at root end when bent around skeleton & was flush at outboard end. All rivet holes are centered in spar & rib flanges. Marked & trimmed lower skin so it's flush at trailing edge. Deburred all holes, cleaned with laquer thinner & primed all mating surfaces with zinc oxide (spray can).
