Laid out center line on bottom of spar. Alligned pre-drilled holes in skin with center line on spar, drilled & clecoed with #40, will updrill to #30 later. Continued same procedure on nose & rear ribs. Laid out skin cut out for hinge brackets to go through. Cut rib angle (7V6-3) to size.
