Brief Description: Nav, Strobe & fuel sender wires in wing
Secured nav & strobe wires in wing. At the wing tip I used spiral plastic tubing around the wires then through 3-adhesive ty-rap mounts riveted to rib # 6. I twisted the 3-wires clockwise to keep them bundled tight between ribs. I didn't use ty-raps on the wire between the ribs in case a wire had to be replaced in the future. The wires are ty-rapped at the root & the tip.
