Laid out & cut a 61 mm hole in tank cover for filler neck with circle cutter on drill press. Deburred & primed with Zinc Oxide, also, primed leadind edge of upper skin at spar. Epoxied a piece of rubber on underside of tank cover (4"x4") to protect fuel tank sender form contact with skin, used JB Weld.
