Marked center lines on ribs & leading edge of rear upper skin (7V7-2) at 10 mm. Clamped "L" channel on front side of spar cap for flush allignment of skin. Drilled out machining holes in rear ribs to 5/16" for rubber grommets to run nav light wires through. Deburred all holes & inserted grommets.
