Fabricated root angle (7V9-3A) to match curve of upper skin & nose rib. Used fluting pliers to make the curve. Cut root skin (7V9-3) oversized. Laid out rivet pattern for Root Skin on Root Rib & Rear Channel. Drilled & clecoed. All edge distances are good.
