Eds Web Site
Date:  10-11-2002
Number of Hours:  4.50
Manual Reference:  7-V-8
Brief Description:  Nose Skin, Drill & Cleco
Filed out slat support slots in nose skin 2mm longer (100mm).Layed out rivet pattern and drilled & clecoed nose skin to ribs. Layed out rivet pattern on spar cap & spar doubler. AN3-5A bolt on spar doubler interferes with one of the rivets that goes thru the spar cap. The bolt had to be be reversed (nut facing forward) for the rivet to clear. Layed out rivet pattern on nose-rib bent "L"s). The bottom rivet hole just caught the bottom edge of "L" flanges on ribs 3,4, & 6. Will add a rivet 10mm up from bottom edge, 4-rivets as per plans. All edge distances OK.
