Eds Web Site
Date:  3-27-2002
Number of Hours:  3.50
Manual Reference:  7-V-6
Brief Description:  Rear Root Channel.Flaperon Support Shims
Rear-rib # 4: installed 2-flush rivets on flaperon shim. Rear-rib # 1: drilled 3-additional holes in root L-bracket & rear root channel flange to compensate for 30 mm flange on root channel. Cut rear-root channel (7V6-1) to 295 mm. Position rear-root doubler to the channel, drill & cleco. Time spent laying out rear upper strut fitting (7v4-4) for fabrication.
