Brief Description: added reinforcement between longerons and wing rea
Cut 1" x 1/8 angle to fit between longerons and wing rear spar behind F-6. Drilled both reinforcements. Clamped in place and match drilled thru F-6. Cut 4" x 3/4" x 1/8" angle to attach to wing rear spar at cockpit seat. Drilled bolt hole through bracket, F-6 and new reinforcement angles. Match drilled upper end of reinforcement angles thru longerons.
Rivet brackets in place clecoed angles in place. bolted bracket to reinforcement and bolted reinforcement to longerons. Riveted angles thru F-6 and riveted bracket to resr spar
