Brief Description: Built Right Wing Structure and Fuel Tank
I lacked in entering the build process for the right wing into this log. The hours are estimated only. I had help from Bryan Blazek, Jim Roeder (my Father) and Judy Roeder. The ribs are all installed, the leading edge is built and installed, and the fuel tank is all built. I still need to leak test it. All the skins are match drilled and the top ribs, skins and wing walk doubbler is all dimpled. On the outer bay I cut in and installed a second Duct Works HID landing light. I need to replace the lense because as I screwed it in it cracked.
