Judy even helped me work on Pro Sealing the fuel tanks. The left tank is completely built and pressure / leak tested and it passed! The right fuel tank is built and sealed with the exception that the rear baffle still needs to be installed. We will install the rear baffle after the right wing is built. I want to test fit before installing and drilling the Z brackets. Cammy and Piper hung out with us also.
