Brief Description: Dimple the Left Wing Leading Edge
Both Judy & Jerry took turns using the DDRT2 to dimple the holes. Seems to do a good job – At least the dimples look good to me. I set up the DDRT according to the manual – Insert the dimple dies, pull the handle all the way until it hits the stop pin, screw the dies down until they are tight against each other, raise the handle all the way, give the die thread an additional ¾ turn tighter, lock the lock nut. Test on a scrap piece of aluminum – insert rivet and check. Looks good to me.
