DOUGs Web Site
Sling 2
Undercarriage
4-3-2019
2 - Modified main gear cover
The main gear curve down before the end of the cover, so I marked this location, drilled holes and then cut slits in the cover so it can bend with the gear. I installed the cover but ran out of 5/32" rivets, so I'll finish riveting later.
marked gear location
drilled and cut ends
installed cover
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
