DOUGs Web Site
Date:  12-1-2018
Number of Hours:  1.00
Brief Description:  Cabin heat, oil tank bracket and fuel pump shroud
I finished riveting the cabin heat control box together and to the firewall. I then riveted the engine oil tank mounting bracket to the firewall. Finally I cut slots in the electric fuel pump heat shroud around the fittings so that it can be removed without removing the fittings if need be.
riveted cabin heat control box to firewall
riveted oil tank bracket to firewall
slotted fitting holes in fuel pump heat shroud
