DOUGs Web Site
Date:  6-15-2018
Number of Hours:  1.50
Brief Description:  Mounted Vertical Stabilizer
I installed an edge protector on the hole of the vertical stabilizer for the wire exit, and then mounted it and the rudder to the fuselage. I installed the rudder cables to the rudder. I also fit the steps to the sides, drilled the holes out for4.0mm rivets and clecod in place. I think the top support bracket needs some tweaking before I bolt and rivet the assembly in place.
edge protector for wire
Vstab mounted
Vstab mounted
steps fitted
steps fitted
