Brief Description: Inboard to outboard wing access covers
Built up the back-up strips and cover plates to go between the inboard and outboard wing panels. Image 1 shows the fitting and trimming of the back-up strips that go under the wing skins at the interface. Image 2 shows how cheap I am. Regular nut-plates for a number 6 screw are 60 cents apiece. Countersunk nut-plates for a number 6 screw are about $3.50 apiece. I chose to use the cheap nut plates and add a spacer that was countersunk. Image 3 shows a typical cover plate fabrication
Making back-up strips for wing -to-wing access covers
