Brief Description: Fabricating left wing bottom stub wing skin
Fabricated the skin for the left-wing bottom stub wing. I basically left everything very oversized and just pinned things up to the spar. Then I used the tried-and-true method of transferring the rivet hole locations (to be drilled) to tracing paper, then after installing the skin, transferred the tracing paper hole locations to the skin with a center punch. The skins were then removed and drilled, then remounted on the wing frame and drilled through the ribs and aft spar.
