Brief Description: Continued working leading edge drilling
Drilled the final holes in the wing leading edges. Image 1 shows hole alignment when looking through the holes that were located using the template (fairly decent alignment with desired location). Image 2 shows the right wing skin with spar holes, final tip trip and fuel tank filler cap all located. Image 3 shows the drain bung location as well as the final trim on the inboard edge including the access panel notch.
