Brief Description: Initial holes in Right wing leading edge skin
Using the tracing paper method previously discussed for the inboard two ribs and tip rib (which cannot be laterally adjusted) I created a pattern for the rivets (shown in image 1) This pattern was transferred to the leading edge skin and carefully aligned with the 9/16 offset line that was drawn on the skin to establish the edge location. Image 2 shows the inboard top side of the right wing skin where the hole locations were transferred (using a center punch set on very low force) Finally, image 3 shows the first holes drilled in the leading edge skin for the right wing.
