Brief Description: Aileron Attach Bracket to Bellcrank Rib Interface
Located the inboard aileron attach bracket on the right wing. I also took this opportunity to remake the rib attach brackets in a thicker (.040) material and extended the bracket legs to better align with the aileron fittings. Image 2 shows the initial hole that was drilled for the aileron pushrod. This hole is currently a 0.75 diameter; however, I have no illusion to think it will not need to be modified when the actual pushrod is put in place.
