Brief Description: Drilled Fin Fwd Spar Attach bolt holes
Drilled the final size for the attach bolt holes on the fwd spar. The pictures look like there is a gap between the attach bracket and the spar, but there is not. the spar is double thickness at the bracket locatioin and the outer spar flange is recessed slightly and does not show in the pictures. The holes were drilled carefully first using a #19 bit, then up to a #12 (0.1890) turning very slowly. The bolts take a light press to get into the location shown.
