Shifted work to the control stick. I fabricated the aft stick receptacle and was not happy with the alignment between the upper and lower pivot points. As a result, I fabricated a second unit as shown in image 1. (Sometimes it is just best to bit the bullet and redo work). Image 2 shows the bushings that were made to fit in the pivot points. Image 3 shows the completed assembly.
