Started work on the lower belly skin aft of the main spar. I was a bit worried that the skin would not want to lay flat since there are compound curves in all directions. however, it turned out that the amount of curvature and the ability to pull the free ends made this a non-issue. Image 3 shows some clean-up work I did after fitting the belly skin. This consisted of finalizing the trim line on the right hand side of the baggage door skin. I also cleaned up all the trim lines on the fore and aft sides of the baggage skin.
