Located and drilled the holes in the fuselage where I intend to route all of the fuel, vent and wiring coming from the wing. These provisions can be seen in image 1. Started fabrication of the splice strips that will seal the gap between the stub wing and wing outer panel. Image 2 shows initial fitting of a strip that attaches to the stub, and will fit under the outboard wing skin.
