Andrews Web Site
Date:  7-26-2023
Number of Hours:  16.00
Brief Description:  Fabricating left wing bottom stub wing skin
Fabricated the skin for the left-wing bottom stub wing. I basically left everything very oversized and just pinned things up to the spar. Then I used the tried-and-true method of transferring the rivet hole locations (to be drilled) to tracing paper, then after installing the skin, transferred the tracing paper hole locations to the skin with a center punch. The skins were then removed and drilled, then remounted on the wing frame and drilled through the ribs and aft spar.
Tracing paper transferring hole locations to skin
Another view of transfer process
