Fitted and drilled the right top wing skin. Started by laying the skin under the leading edge skin to mark for final trim. It did not need much, Drilled holes from leading edge to trailing one row at a time to eliminate any potential puckering. Image 1 shows the new fuel probes I recieved from RED avionics. These probes reach all the way across the wing from the tip.
