Andrews Web Site
Date:  5-16-2022
Number of Hours:  4.00
Brief Description:  Left Wing Inbd Trailing Edge Fit-up
Fabricated and did the initial installation of the inboard trailing edges for the Left hand wing. It is understood that these rib sections will most likely need to be adjusted at the interface flange to maintain proper inboard rib profile and linear alignment with the trailing edge as established by the tip rib.
Left wing trailing edges initial installation
