Progress was slow last week due to out of town travel for a family ski trip, but work resumed on the 21st. Work has progressed on forming the wing ribs. Doing the rib forming was satisfying since its pretty easy to do, and the result appears to be a lot of progress. However, the ribs have only been formed, not completed and fitted. There will be quite a bit of work to go tweaking the flange angles and fit in several areas. Also, all of the ribs require adding stiffeners and various support structures. As a result, I expect to continue working on the wing ribs with much les visible progress over the next couple of weeks.
