Andrews Web Site
Date:  2-6-2022
Number of Hours:  8.00
Brief Description:  Wing Rib Fabrication Preparation
Rib blanks were prepared.
Nose and aft section of ribs were separated as needed to accomodate the spar thickness changes. Radii were added to all bend areas. Back-up blocks were cut slightly inside of main rib forms to allow striking the radius with the planishing hammer, All ribs were then layed out on a 4 x 8 sheet of aluminum to cut out the blanks.
Rib Profile blanks
Rib Profile blanks
Rib sections separated
Fitting ribs to aluminum sheet
