Andrews Web Site
Date:  8-4-2021
Number of Hours:  3.00
Brief Description:  BL:16.5 Rib
Started to build the inboard ribs at BL:16.5. There is a bit of additional challenge here due to the fact that my main spar caps are not bent exactly per the plans, so there are minor chord thickness variations that need to be accommodated in the rib. Also, thinking forward, I am amazed that Dick was able to get such a good fit between the outboard wing panel leading edge and the inboard glove panel. We will see if the minor changes I have to make to the ribs will make that joint even more of a challenge.
Forward BL:16.5 Sections
