Brief Description: Started Aft Wing Spars and Ribs
Bent up the aft spars on the modified bending brake. I should mention that I tried to bend the spars before the modifications, however, I ended up getting a warp 90 degrees to the bend. This caused me to scrap 3 seperate attempts at the spars. I'm glad to report the brake is working much better now. I still managed to scrap one spar attempt because I have apparently not yet learned how to read a scale. I started to build a few of the wing ribs. I save the rib work for a reward for doing harder things. I think forming and straightening ribs is fun. Just for fun, I clamped the BL:39 ribs to the FS:59.375 bulkhead and took a couple of pictures.
