Brief Description: Aft Wing Spar and Bulkhead 59.375 Work
Prepared, painted and riveted the 59.375 bulkhead and aft inboard spar. After setting the bulkhead up in the assembly fixture and carefully measuring the chord line as set by the wing washout and other features, I built up the aft inboard spar parts. Bending the inboard spar sections on the newly modified bending break was much easier. All parts were primed/painted and assembled. The decerning eye will see that I did not exactly following the plans with respect to the stack order of the fittings, bulkhead and .062 spar web. There are some reasons to do this, but we will see if it comes to bite me later.
