Just working on the trim tab details and fit of the hinge to the elevator. Nothing too challenging here. By the way, when fitting the trim tab spar, it is important to check the fit of the trim tab to the elevator to make sure you build it with no twist. (When you cut the skin free in the area of the tab, everything gets twistable again, so you have to watch the rigging.
