Andrews Web Site
Nexus Mustang
First Rib fitting on Tail
Aligned the tip ribs and drilled to spar. ?had to be careful to get centerline aligned correctly even though the tooling holes do not fall on the centerline. Strips of aluminum assist in holding the flanges in the proper alignment.
Tip Rib being drilled
Final location
Nexus Mustang Home
2944
Elevator
246
Flaps and Ailerons
Flight Controls
Forming Parts
1059
Part and Tool Accumu
Wing Spar
868
