Formed root, tip and mid vertical tail ribs. Also formed the opposite elevator tip rib. I noticed that the elevator rib I made yesterday has a very slight curve near the trailing edge. This is due to the fact the at the form block is so narrow, it does not hold it's shape well when forming. The elevator tip that I formed tonight was done with much more balance and light hammer blows. I may remake the first elevator tip.
Vertical tail and elevator ribs (Note Time tag was 12:01 4/24, but work was accomplished on 4/23)
