Brief Description: Rudder Pedals & Position & Brake Master Cylinders
Assembly took longer than I expected. Made sure brake master cylinders were not bound up. Any side pressure would surly cause seals to leak after a while. Shimmed toe brake pedals to middle and used AN3-14 bolt and seven washers to get master cylinders free.
After testing foot pedals in third position, I then move to fourth position. Fifth would too far away to use toe brakes.
