Brief Description: Controls in Frame & Control Stick W/Talk Switch
Finished assembly pg.106 Controls with new roto block and placed in frame.
Note: If you have a push to talk switch for grip, now is the time to put it in while. Crush bushing in the bottom of control stick will need to be notched for wire and grip top modified to accept switch. Also note in Image 2 - the lower arrow points a gap in the tube and crush bushing. I had over tighten. Loosen up a bit and gap went away.
Mill used to notch crush bushings, 3/16 wide by 1/8 deep. Grip drilled for switch. Control stick out of assembly to applying grip. I always have fun doing this. Stick handle shined up and lots of window cleaner and muscel.
