Brief Description: Nose Bearing and Assembly Manual
Now that’s the way it should fit, like glove. Will leave everything loose for now till all of keel put together.
Note: Assembly manual could be better. New Manual in the Works. Have to look forward in manual to not miss other parts that go on nose. Following manual front to back but does not have step by step order of assembly.
The Vortex M912 has new taller mast and is not in the manual. The video and pictures I took at Sport Copter are very useful. Check out the picture and how many things attach to the left upper keel tube.
