Garys Web Site
Date:  11-30-2011
Number of Hours:  1.00
Manual Reference:  Pg 97,100
Brief Description:  Started costruction - Nose Wheel
Just had to put something together. Assembled & checked torque. Swing arm axle tad long so that bearing spacer loose. Lathe fixed problem in no time flat. Only took off a couple of thousands. Man I love my Smithy Lathe.
Note: Talked with Sport Copter about this and it is designed this way. Spacer should turn by hand and still do after I took a bit off. I need to be care full not to change anything until I check with SC about it.
Tubeless tires? I'm thinking tubes and liners for ruff field landing. I hate adding weight but the Idaho outback with a flat. Will ask the guys at the EAA Chapter 328 if needed. Just thinking out loud, I just over think things.
Nose Wheel
Nose Wheel
Make disk holes & bolts line up
