Brief Description: Throttle & Choke Cables to Carbs
I hooked up throttle cables & choke to carbs. Used existing carb hardware to connect except for choke cable tightens supplied with kit. Image #1 shows cable connector moved to short arm on throttle. (Long arm not used) Part would not fit into hole in short arm. Use Letter drill size I to get hole almost big enough for it to fit. (Some filling needed on short arm hole)
Hooked up the two into one cable and am now ready to fasten to throttle quadrant & pre rotator as well as choke.
Have cable dust boots on the way for throttle & choke.
