My 1/2 ton electric hoist will make it an easy job of mounting engine to frame. Crate makes for nice work table for assembly of pre-rotator and engine mount.
One Rotax lift point is to use the intakes. If I was more ambitious I would have fabricated bracket for the center lift point. Still might do that for future so I do not use the cast intakes as lift points.
Set up main table with parts cards for pre-rotator.
